Last of the Dubbydoo's spare parts!
Status
Not open for further replies.
DubbyDoo
all items are priced before shipping
I will not ship out of the country sorry guys
first come first serve
paypal accepted
25$ shipped min order
2 Gauge piller 20$
stock drivers side apillers 15$
shift linkage with kartboy bushings and short shifter 70$
spacer for between the engine and manual trans 15$
3 drivers side axles manual 40$
2 passenger side axles manual 40$
Clutch pedal assm 35$
brake pedal assm 35$
cam mount 15$
cd players both work 15$ each
single gauge pod 15$
prosport water temp gauge and sender
brown 5 speed boot 10$
fog light harness and switch 50$
2 secondary o2s one good one with extension solderd in 30$ for the uncut 20$ for the cut one
gt28 drain flange water line banjos and feed line with turbo fitting 30$
dimmer switches 15$
random sensors in the box 10$
tech one ballast 15$
rad brackets 15$
drivers side motor mounts 20$
wiper/turn signal switches 15$
ac controls 25$
battery tray 10$
ash tray 10$
crusie control actuator 15$
throttle body 35$
ebrake trim 10$
timing covers 15$
washer bottle and bracket 15$
brake booster line 20$
fuse box 20$
drivers and pass side switch panels with switches 30$
cluster surround 15$
intake pipe 15$
kartboy bushings and short shifter, can i call dibs till i find the answer,
any comparisons to stock for the kartboy? Ill try to search on here for it though
well can I just Op out from linkage and jsut have the Shifter and bushings? it would be cheaper to ship since I dont need the linkage. If not then its a no-go for me.
i'm interested on the 2 Gauge piller 20$...the one on the pic looks like a single gauge... is that correct? or is it a dual-gauge pilar?
shipping to 34442, and the fog light switch...would you sell it alone? i have a '00 with no factory fogs and i don't know/think it has the wiring for it, so i built the wiring...just need the switch to make it look "legit"
thanks!
Status
