Koni Yellow REAR Adjustment - How is it done?
steefnap
The thread subject line says it all.
unlike the front shocks which have a dial you can turn, there is no external switch/dial/button/etc you can use to adjust the shock response on the rears. How does one stiffen the rear shocks?
No instructions included w/ the shocks that I could see, and there were no threads dealing with this particular issue.
Twist... clockwise? Counter-clockwise? How many degrees? Is it similar to the front shocks, in that you can do a full 720 degrees from softest to stiffest? And is there a "stop" where you know you've gone all the way, one direction or the other?
what shadrag said.
you will figure out what way is hard/soft. when i originally put mine on i adjusted them the way i wanted and havent touched them since.
