mikwhitesheep
- 2003 Mazda Protege 5
Today, I received my purchased OEM Keyless Remote Transmitter and OEM VIN cut Blank Key that I paid $64.00, was delivered in three days.
Here is the part number for the key:
GD7B-76-201A
Here is the part number for the transmitter:
BL8D675RY
I used the Remote Programming instructions that I found on the forum and they worked. Yet, I think I should add to it through my experience today.
Here are the instructions I used with my addition BOLD BLUE:
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition, get out of the car, shut the door and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Think I just saved around $300.00.[/FONT][/FONT]
GD7B-76-201A
BL8D675RY
