I know you said you checked them, but even so, new batteries should have at least a 10 year in the future date (i.e. > 2032). The fact that yours have 2025 leads me to think "old stock".Both fobs say low battery or key not recognised batteries have 2025 date on them
Thanks, I’ll try that.I'll bet you left the key in the car or close enough to activate the power save feature. The same thing happened to my extra fob and this solved the issue. I swapped the battery to no avail then remembered seeing this somewhere in the manual.
Turning off the power saving function
After you have turned off the power saving function according to the following
procedure, the hazard warning lights and sound operate*1 one time.
1. Press any of the buttons on the transmitter to make sure that the operation indicator light does not turn on/flash.
2. Press the lock button on the transmitter 4 times within 3 seconds to turn on the operation indicator light.
3. Press the lock button continuously for1.5 seconds or longer while the
operation indicator light turns on (for 5seconds).
I have taken my cx5 into Mazda they can’t find anything wrong with the car or fobs the fitter put two new varta batteries in which apparently are slightly thicker never had a problem sinceI'll bet you left the key in the car or close enough to activate the power save feature. The same thing happened to my extra fob and this solved the issue. I swapped the battery to no avail then remembered seeing this somewhere in the manual.
Mazda Key Fob Low Battery Issue
It means it has gone into the power saving mode. Usually when the old battery is about to die, the Fob turns on the Power Saving mode itself. So, from there on you need to get the fob so close to the ignition button to start engine + your keyless entry won’t work.
So, after you change your old batteries and put a new battery, the fob will continue to be in the Power Saving Mode. There are simple steps to take the Fob out of Power Saving mode.
1. Turn on the Engine
2. Use your fob and press your “Lock” button 4 times
3. You’ll see the indicator (red light) on your fob light up
4. Immediately after you see the red light on your fob, press and hold “Lock” button until you see your indicator lamps (green) on your car dashboard flash a couple of times. This means you have toggled the POWER SAVE MODE.
5. Try your keyless entry and try turning on ignition with the keys in your pocket -
This should work![]()
On my 2019 Signature, my "replace key fob battery" message has displayed ever since basically new. Both fobs. Changed to new fob batt 1.5 years later (with no issues during that time) and still have the same message with no actual problems though. I just ignore it. Seems to be a "glitch in the system."
An update from me on this issue ... I too have installed a 2032 size battery instead of the 2025 size battery that is specified. It's .7mm thicker (and larger power capacity) and the little cover with the o-ring gasket inside my fob doesn't fit right but the fob itself snaps closed fine.I have taken my cx5 into Mazda they can’t find anything wrong with the car or fobs the fitter put two new varta batteries in which apparently are slightly thicker never had a problem since
