kenwood sirius ?s
Mazda, Speed 2003.5
I ordered my sirius for my car on the 4th of november i should probably be receiving it any day now. Has anyone had any trouble mounting the antenna in between the speaker plates on the rear deck? That's where i am playing on mounting it cause i don't want it outside the car. Also If anyone can please help me with the kenwood unlock code. I realize i am a new member and don't have much of a status but i desperately need the unlock code! I can give my cell number if didn't want to risk the code being on the forum. Please help! I thought driving without a sub sucked, but it's nothing compared to when you don't have a cd player! Help!
I mounted mine on the rear deck it works great..You might have a problem with mounting it inside the car because you are limiting the range. Just my thought.. I love it!!!!
If you don't want to mess you hands and arms up I would take the unit out.
You will need a unit key to take it out though. I place my Sirius unit under the back seat (middle portion) than ran the wires on the side panel of the passenger side (foot Plate) Now the wire to antenna I ran the wire from the Sirius unit under back seat up through to the rear hatch had some nice wire clips to connect the wire too the ran it outside the truck...
You will get a little wire cover to the antenna I had to modify this piece
To be smaller because it stuck out to much (very easy to do just cut it to size)...
JaysMazdaSpeed said:
thanks for gettin back to me. i'll keep those tips in mind when i get my unit. Hopefully it will be soon
I took off the rear deck cover and placed it in the middle back and put the cover back on. There is a very slight bulge but you cant notice it.
