K&N cone filter on Ractive intake?
What will replacing the filter on my ractive intake to K&N cone filter do for me? Is it worth the money? The filters are pretty pricey and I am not sure what a better filter will do for me and why.
Thanks
Thanks
I dont know what came with the ractive. With the Injen comes a high quality high flow filter, I dont plan on replacing it.
Find out who made the filter and get back.
I am pretty sure it comes with a superflow filter. I would assume Ractive's own. I couldn't find any other info on the filter itself. Are better quality filters to help air flow only? And do they make a significant difference?
"Quality" can mean a lot of things. There are two basic concepts with air filters. Your common paper filter uses a thicker filter element. It looks like a really miniscule screen door, to use a wierd analogy. K&N's and other "high flow" filters use a different concept. They have a much "looser" filter element with a lot more space in between fibers. But they are also a wet (oiled) filter. So the air within that thin filter membrane gets "bounced around" (again using laymen's terms) a lot more. As particles in the air are moved around, they come into contact with oil-covered element strands, which trap the pollutants.
The difference is by allowing more cubic ft of air through per second, they are allowing more airflow to the engine, while not sacrificing filtration ability.
Superflow, K&N, Tochu, all the true high-flow filters work on the same principle. Whether each has the same effective filtration capabilities is unknown outside of testing. The highest flow "filter" would have one strand of twine across an empty hole. Sure, it allows a lot of air in, but isnt catching much. Look to consumer testing for comparison. HP gain wise, dont expect anything noticeable swtiching to K&N though. You are barely getting anything as it is from that Ractive intake. Worry more about filtration capabilities.
hawkwind101, I'm also considering changing to a K&N filter for my intake. I'm not expecting great gains over the filter it comes with. The only advantage I can honestly see is that the K&N can be cleaned and oiled again and again. From everything I hear the Ractive filter is garbage once it's dirty. Since it's not the same cotton gauze material.
If I decide to make the change I will probably go to the U.S. and pick one up at Pepboys and drive back. Over there they run between $25-35 USD compared to $75-85 CDN here. Even with our poor exchange it's still cheaper.(canada)
If the superflow is a wet filter, then it's running the same design (it's wet if you had to spray oil it, or if it was oiled, when you got it). If it's not a wet, dump it for the K&N or comparable.
Ractive can be recharged I believe. And it must be reoiled. So, yes... I believe it is a true wet filter.
