Just installed my CDFP Internals
scatt nasty
Banned
08 Metropolitan Grey Mazdaspeed 3
Don't currently have any logs but the car does drive smoother and my pressure doesn't hit 600's like it did before. As mentioned, no real power gain but they are nice. My LTFT's are at 0 too...
As for the install everything is quite simple. Had to go to autozone to get the E8 torx, the screws on the actual pump are star pattern... Getting the pump off isn't too hard, use the zip tie method and remove the battery box for sure. I left my inlet pipe on and everything went ok. Assembling the internals is easy as well, pretty obvious just replacing stuff. Make sure you use the bowl of gas to dip stuff in though. The only hiccup I had was I forgot to screw that big nut onto the main line, so when I went to crank it I had fuel running down my driveway. I would recommend this to everyone, don't let the complexity of the install deter you. Took me about an hour with 2 people
I did mine a few days ago i can post logs of the difference if you want. Cause it is huge all over.
RPM Before After
2571 1669.33 1659.17
2653 1664.97 1707.03
2735 1592.46 1704.13
2805 1515.59 1701.23
2920 1488.03 1791.15
3096 1515.59 1669.33
3230 1421.32 1753.44
3381 1493.84 1781
3524 1434.37 1778.1
3729 1437.27 1738.94
3868 1453.23 1759.25
4015 1361.86 1725.89
4107 1377.81 1811.46
4237 1274.84 1734.59
4391 1121.1 1795.5
4548 1057.29 1724.44
4684 1018.13 1776.65
4813 1087.74 1718.64
4947 1441.62 1805.66
5081 1711.39 1801.31
5215 1711.39 1714.29
5357 1676.58 1798.4
5423 1664.97 1818.71
5572 1751.99 1718.64
5660 1725.89 1738.94
5787 1666.42 1808.56
5882 1689.63 1728.79
6009 1717.19 1791.15
6097 1672.23 1770.85
6219 1696.88 1743.29
6292 1699.78 1802.76
6388 1675.13 1778.1
6476 1724.44 1843.36
6567 1686.73 1833.21
6643 1707.03 1892.68
6684 1686.73 2050.76
6643 1791.15 1895.58
6482 934.01 2042.06
5778 343.73 1833.21
5026 379.99 1830.31
i want one so bad. its always been the wrong time. either i can't find it in stock or i can't spend money. the fact the car is running more safe makes me a fan of this mod.
Just out of curiosity, i also installed my CPE hpfp today and i swear
that on the cpe instructions, it is pictured that you should throw away
the sleeve that sits on the cam where the spring of the pump rest.
Is this correct or not? The instuctions for the hpfp really suck.
Ok I did a couple runs last night with my AP displaying my fuel PSI.. Had my GF watch it for me... 3rd gear used to drop down to 641 WOT and last night it only dropped to 1690 at WOT lol !!! 4th gear was funny because I've never seen over 2000 PSI and it hit 2040 last night when WOT...
Feels nice to have the extra insurance huh?
BTW...what ap map are you running?
Yeah feels awesome. Im running the v1.03 TMIC map (sri/tmic/tbe) and its amazing.. Will be getting FMIC here shortly though
