LinuxRacr said:I have it sitting in my garage. The thing you have to consider is the fact that the stock ECU cannot control the solenoid that controls the Variable Intake Control System. Without that, it may not be worth it. I would only get the thing put on when I can control this. Other than this, the little black box on top is for better throttle response.
chdesign said:Our ECU's can control VICS as it is a standard thing on our Proteges anyways. Look on teh left hand side (passengers) of the stock intake manifold and you will see the actuator and the control solenoid is on top of the manifold right beside the solenoid the fuel pressure vacuum lines run through.
APEXistud said:According to the guys I spoke to as CorkSport a while back, there is now difference. I was told that the MP3 already has the dual stage intake manifold. I also noticed the actuator on the intake manifold. I messed around with it and zip tied it to see if there was a difference.
