tweety2300
- 2001 mazda protege mp3
What have you guys run into on Jerry rigging? Whether you have done it or some one else.
I have a long list from the previous owners on my 323 along with a few from the protege I've done and my old Honda and other cars
On my old Honda
some one cross threaded the rear motor mount nut, it was re cross threaded when I did the clutch, the brake line got a hole in it I put a small c clamp on it and drove it for 2 days till the new one came in
On the protege
the stock intake tube ripped, I used one off a Pontiac vibe for a year till I did an Sri, the ignitions switch died and couldn't get one soon enough so I did a push button to send power to the starter the key still has to be in the on position.
On the 323
Some one ****** the vaccume lines up and there are still a few unconnected. Somebody somehow used front struts on the rear. It uses a pin to hold the brake pads on on the front, the drivers side had 1 pin on one side and a clothes hanger tied up on the other side. The trans is a fwd mercury Capri along with shifter and shifter rods, it was originally awd and used cables, trans also used a hydraulic clutch Capri uses a cable
On my old Honda
On the protege
On the 323
