James Barone Racing
Performance Aftermarket Parts & Accessories
Spherical Series 2.25" in diameter and 680 grams, this heavy Shift Knob fits perfectly in the palm of your hand. It allows for silky smooth shifts by putting the weight at the end of the shift lever. This gives you greater mechanical advantage and lets the stick glide into gear. Powder coated in Wrinkle Black for superior grip. This is a must for any enthusiast.
James Barone Racing Stage 1 and Stage 2 Short Shift Plate Kits and Heavy Shift Knob Combo Packages
Cylindrical Series Weighing in at a blistering 625 grams (compared to the stock 265 grams for the speed3 and speed6), this heavy Shift Knob allows for smooth shifts by putting the weight at the end of the shift lever. This gives you greater mechanical advantage and lets the stick glide into gear. Powder coated in Wrinkle Black or for superior grip.
Our Adjustable Short Throw Shift Plate kits are the simplest and most effective way to reduce the throw of your shifter by as little as 20% or by as much as 40%. Our kits come to you complete, and include stainless mounting hardware, Loctite and a perfectly matched Counter Weight. Our unique cable attachment point eliminates binding and rubbing of the shift cables unlike the other short shift plates kits on the market. They can even be installed by those with minimal mechanical knowledge in 30 minutes or less. Powder Coated in either Red, Blue or Black for durability and corrosion resistance.
Starting at ONLY $145 Shipped!! (Domestic Orders Only)
International Shipping Available
MAZDASPEED 3 ALL YEARS, MAZDASPEED 6 ALL YEARS & THE 2006 and up MAZDA 3 non Skyactive!!
Link to Combo Package
Starting at ONLY $150 Shipped!! (Domestic Orders Only)
