JBR 3-Way Adjustable Rear Sway Bars in Stock!!
James Barone Racing
Performance Aftermarket Parts & Accessories
$195.00 shipping included!! (Domestic Only)
International Shipping Also Available
Constructed out of 32mm 4130 Chromoly tubing with 13mm thick solid steel arms, Tig welded inside and out with capped ends.
Powder coated in either Red or Black for ultimate corrosion resistance.
The JBR Sway Bar Kit Includes:
-New Greasable Polyurethane Mounting Bushings & Brackets
-Grease
-Loctite
-2 12mm Lock Washers
-Lifetime Warranty
-Online Installation Instructions
Everything you need to get the job done right with confidence!!
Applications Available:
07'-2012 MAZDASPEED 3
04'-2012 MAZDA 3 Sedan and 5 Door
06'-2012 MAZDA 5
Specifications Simulating 1" of body roll:
Stock Sway Bar setting:
MAZDASPEED 3 is 479 lbs/in
MAZDA 3 & 5 is 228 lbs/in
JBR 3-Way Adjustable Sway Bar Settings:
Stiff setting is 593 lbs/in
Stiffer Setting is 718 lbs/in
Stiffest Setting is 901 lbs/in
Thanks,
Jamie
they might have to charge you more and it would take more time to get it since they wouldn't have a blue one sitting in stock already done...But i could be mistaken.
im quite interested, im thinking my next paycheck might be going to one, and it would be a definite if i could get it in blue, i had a Cobb one, but i didnt like it. It kept breaking the mounts and brackets. So i had to go back to stock. which sucks
