- -- 23 CX-5 --
And I'm still wiggin over just adding a piggyback MPI NA tuner..........Gonzo project, good info floating around, keep the encouragement flowing. Subbing the coolness.......
7) "extreme hard mode" is something i've only done once - with varying success - and that is to build a patch harness to allow easy swap backs to stock ECU. This uses nylon male/female plugs, crimps, lots more soldering and a requirement test every connection once they are made. On the car I did this to, we had problems for weeks tracking down phantom wiring problems. Car runs well now...if you're lucky the owner of the vehicle might come and give a testimonial to this method of installation.
One thing i can't save you from is the inevitable soldering iron burns
This is what I have done so far on my Microtech install and I hope it works well. I'll have it up in my build thread soon, maybe this weekend if the baby doesn't come on time. The burns are just battle scars to show you've got balls to do things yourself.
I thought length was calculated from valve seat to where the velocity stack starts flaring out?
