Is 20 pound for the weight like 30 pounds if a guy lifts?
ok that made even less sense than your first post failed to make
Dexter750: if you weigh the 20
Dexter750: will the mans with 30 be less on floor
Dexter750: but not when 20 lbs only lifting 30
d3dz3r0: will the man with 30lbs be less on the floor
d3dz3r0: time 20lbs will lift to travel if 30lbs
post it in your native language and have someone else translate it (wiggle)
i don't have the words..so i found one
Main Entry: insane
Pronunciation: <TT>(")in-'sAn</TT>
Function: adjective
Etymology: Latin insanus, from in- + sanus sane
1 : mentally disordered : exhibiting insanity
2 : used by, typical of, or intended for insane persons <an insane asylum>
AZDriftR said:
No, if a guy lifts 30 pounds for the weight like 20 is like 30 lb when you no lift it to be for men, but I work out floor with 30.
yes, if a guy lifts 30 pounds for the weight like 20 is like 30 lb when you no lift it to be for men, but I work out floor with 30.
thanks for clearing that up truckie!!! (ugh)
oh s***, i think i got it. for every 20 pounds you weigh, you should be able to lift 30 pounds. for example, if i weighed 160 pounds, i should be able to lift 240 pounds. i think.
NO WAY... u sure?
I always thought if a lady lifts 20 pounds for the weight like 30 is like 20 lb when you yes lift it to be for women, but you work out the floor with 20.
WINNAR!!!!
damn, now i wish i didn't get it. it was actually more fun trying to figure out what you were trying to say.
