AZDriftR said:No, if a guy lifts 30 pounds for the weight like 20 is like 30 lb when you no lift it to be for men, but I work out floor with 30.
thanks for clearing that up truckie!!! (ugh)tonkabui said:yes, if a guy lifts 30 pounds for the weight like 20 is like 30 lb when you no lift it to be for men, but I work out floor with 30.
NO WAY... u sure?tonkabui said:yes, if a guy lifts 30 pounds for the weight like 20 is like 30 lb when you no lift it to be for men, but I work out floor with 30.
tonkabui said:oh s***, i think i got it. for every 20 pounds you weigh, you should be able to lift 30 pounds. for example, if i weighed 160 pounds, i should be able to lift 240 pounds. i think.
