Intermittent problem in starting
tsingo
My 2011 CX-9 has been running great but recently it started to show a problem in starting. After I turned the key the engine wouldn't start. There is no noise from the starter but the dashboard lights are on. It took 6 to 10 retries to start the engine. I thought it might be a low battery in the remote so I changed the battery in both remotes but it didn't help. The remote can lock/unlock the car just fine. It didn't help either if I inserted the key to start the engine. It might be also my car battery but I am note sure because I changed it one year ago and also once it responded the engine started without any hesitation. It has happened twice in the last week and it is right after I did the airbag recall repair at the dealer. Any suggestion about what I should look for?
