Something must be loose. The power delivered to the dedicated cel phone recepticle in the center console is intermittent and much affected by bumpy roads. I don't use it that often to charge my phone but I do like to use it with WAZE. Unfortunately the system sort of toggles between connected and not connected so I keep getting my map then losing it further down the road. I wonder if a fix (some kind of replacement) would be fairly easy or very complicated. As it is intermittent I do get the map some, even most of the time (on smooth road) so hesitate to bring up the issue with Mazda. I don't want to spend a week without the car over a USB port. Anyone had a similar problemand if so the cure?
