Interior Lighting
Just checking..thanks.
Pretty stupid cost cutting measure. At night you have to feel around.
What about the instrament cluster?
I just drove it, I mean really drove it, for the first time.
It's my wifes primary vehicle. The cluster is SOOOOOOOO dark! I've tried to adjust it but no luck. Any ideas????
which trim level do you have? the cx-7 has different gauge lighting depending on trim.
there is an adjustment knob on mine up sticking out of the gauge clusters.
Above the tach, near the speedo is a knob. Twist it to adjust the brightness when the lights are on. You can also press it and the dash lights will go to the full bright that is used when the lights are off. That should be bright enough for anyone who can see well enough to drive.
(laugh)
Everything inside would go bright, just do as AWmustang said, and the blue should come off.
We are still talking about the instrument cluster right?
Latest posts
