Interior Light Control Unit
tgee
Mazda Protege 1999
Hi, i have a 1999 Protege, the interior light does not work on "doors opening" only when switched to "always on". I have also noticed the "doors open" on the instrument panel does not work. I have dropped the centre dome light and all connections and switch operation seems fine, checked all door switches which also seem fine. I looked up a wiring diagram and it mentions an interior light control unit, does anyone know where this is and what colour it is? Many many many thanks in advance.
hi, i have checked all door switches and they seem fine, i assume the fuses are fine as the interior light in "on" position works but checked all of them anyway and they are good. i have even checked the blue/white wire behind the dash as discused in other threads to stop the buzzer/door open and i also checked the conection behind the ignition switch also used to stop door buzzer and they are all connected. loks like i need a wiring diagram, any advice much appreciated.
