Walking into this and deciding to vomit text anyway, is this possibly a case where an upgraded TMIC is a HUGE improvement, and a FMIC is an AWESOME improvement? I want to upgrade this summer (HOT in Louisiana), and aim to prevent heat soak, but I'm not autocrossing or drag racing, just tearing it up around town. Would I *need* a FMIC, or would a great TMIC provide significant improvements for quite a bit less money and install trouble? Bear in mind I'm in bed with the bank, and might have to get it off in a hurry if I need warrant service.
And does anybody have links to that TRZ TMIC? I'm becoming a TRZ poster child...
Maybe a little off-topic, but looks like there have been some fitment issues with the ETS, has anyone had problems with the SU TMIC?
I was going to get a DP next, but me thinks maybe better to get a TMIC first!
I would never consider upgrading the stock unit with another TMIC. Regardless of improvement youre still going to get some serious heat soak.
If you believe that pressure drops are as bad as people make them out to be, then you need to think again. Turbo lag seems to be a big issue with FMIC's with you guys as well. Although there is minor turbo lag in an FMIC over and TMIC, its imperceivable. As far as pressure drops go, getting a really nice FMIC (such as a COBB) will afford you the lowest possible pressure drop.
Why upgrade a TMIC with another TMIC? Regardless of initial cooling improvement, you're still going to get a lot of heat-soak under the hood. Why not just go with an FMIC? You have to take into consideration the efficiency of your intercooler. Sure you can go with another TMIC, you'll gain a bit of power and efficiency, or you can just upgrade it to an FMIC. Sitting up front obviously bring in the coldest, most dense air. With it sitting up front, you'll lose hardly any efficiency.
QFT. If you have the money.. FMIC ftw.
Does anyone on here have this bad boy nobody talks about it. http://www.youtube.com/watch?v=e1N6o94qrrg
