I think I remember hearing that it would not be a benefit to vent the hood, as the grill opening, hood, and intercooler have been specifically designed together to provide airflow.....
then again, I might be wrong
You would basically wrap the whole underside of the intercooler...any area that would be hit by direct heat.
I don't think you would wrap the intercooler. You need to create a nice wide heat shield to go between the IC and the engine, as far from the IC as possible to limit interference with air movement and insulate that. It would be extra trick if you could shape it to funnel the air to the back of the engine compartment and put a vent in the hood to carry the hot air out. Complete the path. There is already a reasonable supply of cool air coming in, we need to help it get out after it heats up.
i think the fan idea is pretty interesting, is it an easy drop in like replacing a computer fan?
eventually to get rid of some heat issues if i ever go with a dp, ill be jet-hot coating the piping, manifold, and hotside of the turbo.
I fixed my heat soak by previously owning a VW 1.8T with a side mount IC the size of a lunchbox.
YOU DON'T KNOW HEAT SOAK. (flame2)
**** Fmic ****
**** Fmic ****
