Intake Sounds??
2003 Mazda Protege
i put a ractive cone filter on my intake and when i shut down the car it sounds like air comming out or something, what is it?
also there was a sensor or something that was connected to the stock air box, i had no where to plug it in so i just left it aside, and it hasnt run any codes, so i guess its good? or is it?
thanks.
i will post pictures of it 2nite :)
Yea my Simota makes that noise when i turn it off. i think its pretty sick. as for that sensor, i would say its the Maf but then ur car wouldnt be running so post a pic like u said u were goin to.
thanks.
the sensor thats probably hanging sounds like your temp. sensor. It reads incoming air temperatures and adjusts AFR accordingly.
Am I to understand that you just disconnected the stock airbox and attached a filter to the stock piping?
if this is the case then just secure the sensor (should be a wire probe that resembles something like an antenna) so that it run next to the cone and reads the air as its being pulled into the cone. Otherwise, its fine left hanging (it just might read a few degrees differently than the actual air entering the intake)
i have a AEM sri and it makes that sound when i turn the car off and i love it. there is nothing wrong with the intake if it makes the air swisss sound.
thats exacty like it sounds like. well its all good then ! i like when i shift it goes pst . sounds like a blow off valve but not as loud, thanks for the replys guys!
and yeah i just zip tied it to the intake, near the filter, and no codes have come so thats cool!
if I remember correctly, that sound is the compressed gasses of the cylinder that didnt fire shortly after you turned your car off. The gasses escape out of the intake port and then out of the intake itself.
According to those scientist people, this is the largest cause of negative emissions from cars and most modern car makers are designing carbon filters in their air-filter compartments to counter this.
you probably don't want to run the stock rubber hose with a filter for too long. the filter will bounce around and get dented and the hose will wear out after a while. as for the little temp sensor, i drilled a hole in the hose and shoved it back in when i did it. i then made a bracket to hold the hose up. i connected the bracket to the maf and the bolt at the battery box. doesn't matter now though, got the k&n typhoon on.
I used a coathanger to hold my stock rubber hose in place with a filter on the end, it worked fine and controlled the bounce. But now got the tubing so im good, and is it supposed to sound like you got a hole in your exhaust with the sri?
jeg0024 said:
No, but its suposed to sound like your homeless and stole a retards car if you have clothe hangers holding up your "stock sri"
Are you ok Willis??? You shouldn't talk s*** man... im gonna kick ur ass!(friday)
i r has a cons fltres on mi rubbar hozes and i gets de fonnny nouse too, i had no whatss ups wid dat mon
Cool, more stuff to take off of a car when I buy it! the more emissions control bs they put on a car, just makes it more of a fun tear town when i mod it!!
