Remove the 5 or so pop clips on the rear deck cover. Then push up on the ledge of the rear deck as there are several pop clips by the rear seats. The back of the deck is slid clips and once teh fronts are pushed up you can just slide the entire peice toward you. The little flapps by the side can be opened to allow the seat bets on each side to slid out of the rear deck lid. Lastly use a key to release the middle seat belt latch and out the plastic deck cover comes exposing the rear speakers. After the first time you will be able to remove the rear deck.
Hope this helps. Don't get pised if I forgot something as I am pulling form memory here.
