MP5stephen
- Mazda Protege5 & Miata M Edition
Ok, so I installed this short-ram intake maybe 3 weeks ago. My old one was rotting out, and I payed about the same price for a short-ram, as I would for a new one with filter. I installed it properly(connected all sensors back/etc.).
But there are 2 things that don't fit back where they're supposed to:
1) Looks to be some sort of ground from a plug? It was bolted above my stock intake hose, but the short ram doesn't allow you to attach anything to it. For now I have it zip-tied to the strut tower stabilizer bar(the tie has broken off once already and I had to put on a new one). I don't see where I need to relocate this?
2) This I believe is the breather hose from the engine(it connects to the side of valve cover), I am not worried about it being a problem, although it concerns me that it's open/exposed. What should I do about it? Would it be bad to clamp it off so nothing can get in?
Please help and give me a solution as to what I should do. If you had the same issue, what did you do, and did it work?
Thanks!
Thanks!
