you can, or you can get it reflashed, but you'll need to find someone with an MP3. As far as HP, i think it's good for 3-5 whp as it advances the timing and leans it out (i think). Once you have it, you'll have to run higher octane fuel because of the advanced timing.Can you just swap in an MP3 ECU? What are the HP gains?
i stand corrected. Why are you measuring AFR on your car? Or was it at a dyno?no it doesnt lean it out, it just as advance timiing. my car's ratio with the mp3 ecu at wot is 10.0:1!
