- 2009 Mazda 5 Touring & 2012 MS3
These are always fun..until you realize what a challenge it can be to remove the interior panels needed (nervous)
With a little patience and a careful hand this is easier than people think.
The first step in any car audio install is to remove the negative battery terminal. I learned this the hard way, but before killing power, shift the van into drive. You'll see why later...
So, unscrew the shift knob and pry off the trim surrounding the shifter. I have a set of plastic automotive interior removal tools i bought from harbor freight for a whole 5 bucks. Go get a set then come back or you will be gouging your interior up with a butter knife.
Next i pried the cupholder of off the center console.
Now you can pry off the small change pocket/12V that's right below the shifter. There are connectors behind it so pull carefully. Remove the connectors and set the piece aside.
Move to the rear of the center console and remove the rear A/C controls, if you have them. They pry off as a single unit, no screws. Careful with the connector. Also remove the screws at the bottom as shown in the pic.
The console has a two more screws right at the base of the dash before you will be able to lift it up and back. Great time to deal with any coffee stains
I didn't completely remove the console but you can if you want. I just didn't want to deal with the other screws required to remove the whole thing. Tilting it back and over the e-brake gave me enough clearance to work. To remove the final, LARGE piece of the dash you must locate the screws on the side of it, at the base. The big red dots show where the two screws are. are Note the blue interior removal tools on the seat.
another angle taken from outside the car looking in. Pop the caps and and remove the screw. one on each side.
There are yet two more screws at the rear of it near the gas pedal and in the same are on the opposite side. There are panels covering it that quickly pry off. Here's a shot with the panel already removed, showing the screw that needs to be removed from both sides
now with the all the screws removed, you have to carefully pry it from the bottom of the hvac controls. it's a force fit that needed some serious lovin in my case. One side of it just wouldn't let go. I ended up sticking a flathead into the snap to release it. Lift the whole assembly up over the shifter. This is why you put it in drive first. You will also have to remove the wiring harness from the front of it or it will snag. You'll know what i mean the moment you pull on it.
You will now have access to the two screw holding the radio/hvac trim piece in place. With the screws removed, use you interior removal tools to pry at the top of the trim piece. The radio and trim will come out as one piece. Be sure to disconnect the wiring harness before yanking too hard on the radio.
And you should now look like this
I went a step further and removed the hvac controls. The more room the merrier. Just gently pry it off and remove the two connectors on the rear of the unit.
Quick test fist of the Metra dash kit. Crutchfield includes it for free. It's crap but better than nothing. i may swap to the Scosche kit come summer.
All panels fully tilted back, awaiting a shiny new touch screen
