well i do work for Vivid Racing so getting parts next to cost isnt far fetched. Now all I need to do is save up for a Kenstyle Body Kitjebus said:i am talking about dealer cost guys
not if you buy it
I can get stuff for dealer cost also since my friend owns an import shop here in dallas
Well then, hook us up with some prices on a group buy. ;-) (yes)jebus said:i am talking about dealer cost guys
not if you buy it
vividmaz3 said:so cost is going to be around $100 then?
Da 6 said:Injen sends cels as a cai on both 3 and 6 2.3.....injen claimed they never recieved one because they never tested the intake more than 20 miles. it takes 100 miles for the intake to throw a cel...they claimed to researched the problem and ended up getting a heat shield to stop the cel problem...I have a short ram that never threw a cel and I converted it over and the cel came back. and if the intake is anything like the 2.3 for te 6 then injen is gonna run you $239 and aem is some where in the same area for consumer price. Wait a lil bit and ebay will sell them for like $189 aem. make shure it says cai and not short ram...or you will be like me...
mazda3zoom said:what the hell does throw a cel mean? (uhm)
goldwing2000 said:Illuminates the Check Engine Light.
It's not the quality of the product but the maf and pcm going bonkers at the gained hp....lasermp5 said:injen is a good company.
the air box is restrictive...the resonator is restrictive....VVT reponds...if you choose to not get one or ignore dynos what more can we say.Mach 1 said:11 hp gain...hihi...lmao...not gonna happen.
Da 6 said:It's not the quality of the product but the maf and pcm going bonkers at the gained hp....
in technical terms.....
Check Engine Light is thrown when the engine compares the Short Fuel Trim to the Long Fuel Trim and finds greater then a 9% difference. The Short Fuel Trim is basically a realtime collaboration of data, which is a reflection of the current air/fuel ratio. The Long Fuel Trim is based on a default map (which is reset anytime you pull the negative battery cable, or reset your cel's with a scanner) and changes after each drive cycle by taking the SFT's data into itself.
Thus the computer has the capability to adapt its settings over time to a variety of conditions. If a change is introduced (more air from a CAI for example), and the SFT changes by a significant amount, the PCM marks a possible problem as a pending code. If two concurrent drive cycles occur the PCM throws a check engine light, to let you know a difference is occuring.
