2003blkmp5
Here is some usefull information. I have seen a lot of threads out there regarding people worring about sucking up water into the Injen CAI. The Injen CAI can use the AEM Bypass Valve which reduces the risk of sucking up water into the engine, but it also reduces HP gains because of its shape rough internal edges ( Source from AEM's Website). Here is the link to where you can get the bypass valve
http://www.eautoworks.com/html/ord-auto~performance-AEM~Bypass~Valve-1-3616.htm
Also. here is a little tid bit from Injen's website about how much water it would actually take to damage anything. from what i understand you would have to hit a pretty damn deep puddle (probably a pond!!
) to actually do any damage.
MYTH: A bypass valve cannot be used on an Injen Intake System.
FACT: A bypass valve can be used on most 2.50", 2.75", and 3.00" applications.
MYTH: Water will enter my engine and damage it.
FACT: The most common way for water to enter the engine is for the filter to be entirely submerged. The length the water would then have to travel, significantly reduces the possibility of harm being done.
Just thought i would share this usfull information with everyone!
Ohh by the way my Injen is comming today!!! YEAH!!!!
