IL Track Tested: 2010 Ford Taurus SHO vs. Pontiac G8 GT
Which American sports sedan?
  • 2010 Ford Taurus SHO
    Votes: 6 20.0%
  • 2009 Pontiac G8 GT
    Votes: 24 80.0%
  • Total voters
    30
mikeyb
Contributor
01 BMW 325xi Touring
Inside Line tests hundreds of vehicles a year, but not every vehicle gets a full write-up. The numbers still tell a story, though, so we present "IL Track Tested." It's a quick rundown of all the data we collected at the track, along with comments direct from the test drivers. Enjoy.
Since the day the name Ecoboost was first uttered at an auto show, it's been touted as an engine that would offer V8 performance with V6 efficiency. Well, Ford's twin-turbo 3.5-liter V6 is finally here and the 2010 Ford Taurus SHO is the most performance-oriented vehicle yet to offer the new engine.
Still, the latest Taurus is a hulk of a sedan. It weighs in at well over 2 tons and stretches nearly 17 feet long. With that in mind, it seemed only fitting to compare the SHO to one of the biggest, most muscular American sedans around (at least for now) -- the 2009 Pontiac G8 GT.
Now technically, the Pontiac G8 GXP is a closer competitor in terms of price, but the GT's power output nearly matches the SHO. Oh, and the Pontiac is 300 pounds lighter, too. We also took into consideration that our Taurus didn't have the optional performance pack that adds a shorter rear end gear, stiffer springs, a thicker rear stabilizer bar, high-performance brake pads and summer tires. More importantly, adding the performance pack also gives you the ability to turn off the stability control system completely, a big advantage when you're running numbers.
So how did the "new" SHO measure up against the "old" GT? Click for the full results; you might be surprised.
Vehicle: 2010 Ford Taurus SHO
Odometer: 2,289
Date: 06/16/09
Driver: Chris Walton
Price: $45,475
Specifications:
Drive Type: All-wheel drive
Transmission Type: 6-speed automatic
Engine Type: V6
Displacement (cc / cu-in): 3,496cc (213 cu-in)
Redline (rpm): 6,700
Horsepower (hp @ rpm): 365 @ 5,500
Torque (lb-ft @ rpm): 350 @ 1,700
Brake Type (front): Ventilated Disc
Brake Type (rear): Disc
Steering System: Electric power steering
Suspension Type (front): Independent, MacPherson Struts with stabilizer bar
Suspension Type (rear): Independent, multilink with coil springs and stabilizer bar
Tire Size (front): 245/45R20 99V
Tire Size (rear): 245/45R20 99V
Tire Brand: Michelin
Tire Model: Primacy MXV4
Tire Type: all-season
Wheel Size: N/A
Wheel Material (front/rear): Alloy
As tested Curb Weight (lb): 4,404
Test Results:
0 - 30 (sec): 2.4
0 - 45 (sec): 3.9
0 - 60 (sec): 5.8
0 - 75 (sec): 8.7
1/4 Mile (sec @ mph): 14.2 @ 99.11
0-60 with 1-ft Rollout (sec): 5.5
30 - 0 (ft): 31
60 - 0 (ft): 127
Braking Rating: Average
Slalom (mph): 62.9
Skid Pad Lateral acceleration (g): 0.80
Handling Rating: Average
Db @ Idle: 44.1
Db @ Full Throttle: 71.8
Db @ 70 mph Cruise: 64.1
Acceleration Comments: The SHO didn't respond (good or bad) to brake-torque, so best launch was at 2,000 rpm. Revs didn't fall (good) but things didn't really start 'till 3,000 rpm. Upshifts at 6,250 were smooth but not especially quick. Accel was linear until end of quarter-mile where it lays down a bit. (Smoking brakes after 5th accel run.)
Braking Comments: Gravely tire noises, moderate pitch, soft pedal goes nearly to the floor. So-so initial bite, good in the middle then soft at the end.
Handling Comments: (Skid pad) Chassis is slow to respond to steering input -- not at the sidewall level, but due to body motions. Understeers with maintenance throttle and lifting to get rotation awakens stability control. (Slalom) To keep from arriving late at each cone, I had to dial the speed down. Friction-free steering with mild load-up. Just as understeer begins, stability control starts grabbing brake, then throttle dips. Would be nice to turn off stability control, but you can't do that unless you get the optional performance package. That same package also adds better tires which would likely improve results.
Vehicle: Inside Line's Long-Term Pontiac G8 GT
Odometer: 2,675
Date: 04/28/08
Price: $31,845
Specifications:
Drive Type: Rear-wheel drive
Engine Type: V8
Displacement (cc / cu-in): 5,967cc (364 cu-in)
Redline (rpm): 6,900
Horsepower (hp @ rpm): 361 @ 6,300
Torque (lb-ft @ rpm): 385 @ 4,400
Brake Type (rear): Ventilated Disc
Steering System: Speed proportional power steering
Suspension Type (front): Independent, MacPherson struts, coil springs and stabilizer bar
Suspension Type (rear): Independent, multilink, coil springs, stabilizer bar
Tire Size (front): 245/40R19
Tire Size (rear): 245/40R19
Tire Brand: Bridgestone
Tire Model: Potenza RE050A
Tire Type: Summer performance
Wheel Size: 19-by-8-inches front; 19-by-8-inches rear
As tested Curb Weight (lb): 4,021
Test Results:
0 - 30 (sec): 2.3
0 - 45 (sec): 3.9
0 - 60 (sec): 5.8
0 - 75 (sec): 8.3
1/4 Mile (sec @ mph): 13.95 @ 101.3
30 - 0 (ft): 28
60 - 0 (ft): 113
Braking Rating: Very Good
Slalom (mph): 63.4
Skid Pad Lateral acceleration (g): 0.86
Handling Rating: Good
Db @ Idle: 48.1
Db @ Full Throttle: 76.9
Db @ 70 mph Cruise: 68.1
Acceleration Comments: Why is there no redline on the tach? Isn't this a sport sedan with a powerful engine? Bizarre, especially since manual mode holds gears and will bang off the rev limiter all day long. Quickest accel times came in Sport setting with transmission shifting on its own. There's very little wheelspin at launch.
Braking Comments: Some fade became obvious after 5-6 stops, but the distances continued to come down to a world-class 109 feet. Some ABS kickback is noticeable through the pedal, but the overall brake feel -- at least prior to the minor fading -- is confident.
Handling Comments: Transition to oversteer isn't as intuitive as I'd like. Perhaps this is due to minimal roll stiffness. Once the tail is out, however, the G8 GT is easily controlled. Little roll stiffness also means there's an uncomfortable amount of time between weight transfer in transitions in the slalom. Otherwise, handling is good with predictable limits. Oh, and stability control can be fully disabled.
as much as i love my blue ovals, i have to give the nod to the G8 GT here...Much better execution than the SHO...
The Taurus is a pig. But that is what happens when it shares a platform with a minivan and SUV.
not a fan of the taurus, any of them for that matter. I give it to the G8 because I would much rather put an exhaust system on a V8!!
A $50k Taurus? WTF? Once you add the sport pack that is the most overpriced POS of the decade.
I'll take a 335 and a Yaris for my $50k.
I don't think the SHO is really performance oriented like the G8 is. It has a minivan platform and in turn is freakin huge. G8 is an Australian muscle car, and has more sport oriented features (suspension, tires, brakes). For god's sake the Tarus rides on Grand Touring All Season tires!
SHO... in their eyes that is performance oriented.
And to the people they are marketing to like my 45 year old father it is a performance sedan. He likes the G8 but would never buy one and is thinking about getting the SHO.
My 55 y/o father would not even consider the SHO. He loves a drivers oriented car. He would not even consider either of these. He would consider a G8 GXP 6 speed. But he is more likely to go over to the BMW center and buy a BMW 335i sedan.
you're father's a smart man :) 335I > anything american
That Taurus weighs in at about one and a half Mazdaspeed 3's. Gonna need a lot more than another 100 horses to make it performance worthy. On the other hand, that engine may be a fantastic platform for the future of Ford performance vehicles.
Just don't stick the damned thing in a brick with wheels next time, Ford. GG
I really think the Taurus itself is a great car, but the SHO is lacking. Putting a performance oriented badge on a mediocre car is not a solid move.
With that said, I'd go with the G8 in this case. Dead or not, the car is the epitome of what Pontiac should have become.
Kudos to the latest Ford Taurus SHO (still very fat and large for my taste though), but G8 beats it hands-down (stylewise to say the least).
SHO: Who would ever pay close to 50K for a taurus.....thats like paying 30K for a Civic.
Plus dang that SHO is bloated. I've seen navy gunships that weigh less.
G8 please.
New Threads
