Ignition Voltage Booster to Increase HP/TQ?
Dstrong210
CX-9 GT AWD Pearl White
5Zigen Pro Racer ECON ignition voltage booster.
Found this article and was wondering if it might work with the CX-9. I'm not a gear head so I don't know what variables are required (unless it is as simple as the amount of power being used up) to see increased performance while maintaining engine stability.
http://www.importtuner.com/powerpages/impp_1106_2009_mazda5_sport/viewall.html
More info on the product.
http://www.frsport.com/5Zigen-Pro-Racer-ECON-Ignition-Voltage-Booster_p_16643.html
Thanks for the input!
In the end, exhaust and intake modifications still give you the best bang for the bucks.
I would do many things before zapping more electricity into the spark plugs. better cams, exhaust, intake, ecu chip/timing mod, etc. Adding more zap into the electrical system sounds like a recipe for a short life span.
