I did a search, but didn't learn much.
I would like to bump my timing up from 8 BTDC to 10 or 12 - How ever far it turns out that I can go without needing premium fuel.
I understand the timing is adjusted by the ECU, but I'm assuming there must be some procedure for changind the base timing - I know there is on my Miata, and I've made good use of it. On a Miata, you disable the ECU timing by shorting two connector pins under the hood, and then set the base timing by adjusting the cam angle sensor.
Is there a similar procedure for the P5 engine, and has anyone written it up anywhere? If so, my "search" didn't find it.
Thanks,
Don
Thanks,
Don
