Imagine that eh? well anyway, i bought the car 2 and half years ago and ever since i've had hassles with idle probs. In the last few months on a cold start, the car won't idle in the 1500-2000rpm range anymore. On a cold day i will need to hold the gas in a lil bit so it wont stall out, but on a warmer day it dont need to touch the gas and it will idle around 800rpm. Once the car warms up to normal temp, there is no idling issues. It used to throw a cel, something about idle solenoid intermittent. I cleared the code a few times, altho i havent thrown a cel in a few weeks now, the same problem persist. I have taken the IAC off several times in the past and put some seafoam thru there. That fixed the problem but only temporarly(lasts maybe a week or so). I did somewhat of a test on the IAC today, while car was idling I disconnected the black plug goin to the IAC and nothing happened. I remember in the past when i did this the car would stall, but not this time. Does this mean its stuck or not working anymore? remember idle is fine at normal temps. Anybody got any ideas? Not trying to buy unessecary parts here. Oil and spark plugs are regularly changed. All vac lines and egr where replaced earlier this year. Any help is appreciated
