(ID) 2.0 full supercharged kit
Status
Not open for further replies.
well since i will prob be runnin it on a stock block with no forged internals, how much psi can i run? or does it not matter cause its a supercharger? also if it can run up to like 12 or so psi can it be tuned so i can run a safe amount and still floor it?
6, i think is what the msp runs. its considered unsafe for pass 9 tho
8 if untuned, 10 if tuned. I'd imagine psi is psi though, 12 on a turbo and 12 on a charge should be the same amount of stress on the rods and pistons.
everyone on the boards say 7.5psi and 9psi max.
if you want to run on the stock pully you will make 4.5psi - 5psi
I have made max 9.5psi with my minor boost leak, so you could just hook it up see what you get, and not track down boost leak
not exactly, its my tune so it would be a rough tune for you. but it can tune itself. I will teach you how when you buy the kit. if you want look up Megalogviewer :)
lol don worry i may possibly have the money in 3 or so weeks
im goin to def try and get this kit
i think it would be awesome to have this set up on my protege
hopefully it would be a easy install
Status
