(ID) 2.0 full supercharged kit
Status
Not open for further replies.
it does have a clutch and i had a 12v switch controlling it, so I could turn it off and on
as far as your idle question, the BOV would stay open letting air out of the system so the engine would not be under pressure, then you would take off, and the bov would close putting you in boost :)
if somebody buys the kit without the water injection then i cold sell seperatly, but for now I would like to keep them togethor for good cooling :)
the whole thing is still available!!!
so this is a comlete kit?
can i jus put it on as soon as i get it and not need anythin?
or will i need some misc things such as clamps, hoses ect...?
everything is there, might need a vacuum line and a T for the BOV
as far as an automatic, mechanically it should fit, not sure about how it would run
It would run fine. If you wanted to do this on an auto, get a transmission cooler and you're set. Keep boost at a comparable level to what a stock MSP turbo would provide and you're fine.
Oh I've done A LOT of my homework. All of it is thanks to the forums but mostly the help of another member. There's a lot to learn and know about.
Haha, I know YOU have, to me an auto booster should look into the stuff MORE than a MT booster since u gotta worry about the tranny.
I was referring to Adam, he seems to know a lot of FI stuff considering his age and how he is not currently buying parts to boost compared to another OH member on here. (evil)
thanks you
yes. i do my hw, im fascinated on ways to make a car go faster and how it dose it. ive always liked cars.
Status
