i need a motor quick :(!!!!
damien510
Mazda, Protege5
well i have an 03 protege5 and well it has 81,kkk and i threw a rod! so i need help finding a motor and some advice thanks!
evryones telling me that the 2.0 is the only thing that will fit. and i cant find one whats the kl?
Klde is a v6 it will fit but requires a lot of wiring headaches but look on ebay there is always one around
If you need a motor quick, a KL swap is probably not what you're looking for. It will require quite a bit of work and rewiring, and it sounds like you need a replacement motor fast. I would go with a drop-in 2.0L FSDE if I were you.
Wow, all these low mile engine replacement threads are starting to make me worry.
Its that these cars are beat on and even then thats not 00% the reason why they fail. I think its more then likely they are over reved but thats me. I had a auto fsde with full bolt on and it saw redline every take off just about. To make a long story short 170k miles when i traded it in and it didnt burn any oil and was still on the orig motor.
