I have been all over the board trying to figure out what I want to do for oil cooling, and I think I finally decided on something. (but then again, I've said that before too).
Rejected ideas:
FM oil cooler: I feel the mounting location is far too risky, and I've found some people that have had first hand experience with damage to it
Wheel well cooler: This is only marginally better, and eliminates the chance for good brake ducting in the future
Laminova Oil to water exchanger: Unsure that I have the water cooling overhead. Bill @ FM doesn't think I will.
Custom fabbed brackets to mount so the vents from the closed hood will sit right over it: The space exists, but will cause problems with any work performed, plus semi-requires that I have a vented hood for the street too
Transmission cooler mounted under the car tucked up above any bracing: Simply no room available. I didn't realized how generally flat the MSM is under there. Quite different from the 99.
Mounted immediately behind one of the fans, so the fan is pushing air through it: Same 'no room' story
New idea?
One of these (or one like it)
http://www.jegs.com/i/Derale/259/13256/10002/-1?parentProductId=1533912
Mounted here:
That is an RX-7 oil cooler, and the discussions around mounting it there indicate that it completely works. There is no airflow over it there, but they say it works anyway due to the size. It's just a big heat sink at that point.
So my theory is, using an actual heat sink method, and running a short length of ducting hose on one side to collect some air and send it across the heat sink on the crash bar.
The flaw with this is of course that it becomes the first point of impact on my crash bar. However, if I'm crashing on that, I probably have larger concerns that will prevent me from driving away so I don't think it's a huge concern.
