TRexPro5 said:If I am correct a warrenty and a TSB are two diffrent things. TSB should be corrected no matter what. However, juding by your sig you have a short shifter. They will probably blame your shifter for it. Good luck either way though!
This may be a very dumb question. What is a TSB? Technical Service Bulletin? And are they supposed to fix these regardless? And if so, what is the difference between a TSB and a recall?
