I was recently trying to take out my stereo and pulled to face plate off from around the radio and heater. I had to pull kind of hard to even see behind the panel to where it was held in place. Short story, I didn't end up taking it off, but replaced everything only to find the heater barely works, and only when I have it at the hottest setting. If I turn it slightly down it is on cold full blast, and the hot is only slightly warm. Needless to say, this winter has sucked.
I was told that there is a cable that adjusts the heat in the back of the panel, and that I might have messed up its position. Can anyone help, I would like to do it myself and not take it in if at all possible.
Thanks a lot,
John
Thanks a lot,
John
