I am having problems.
YayArea420
2003.5 Titanium Grey
I am having problem with my cars RPM's dropping to 0 and then jumping back up again. It only happens when I push in the clutch. Everytime I push in the clutch it happens. The only mods I have are turbo hoses hardpipes and a drop in K&N. Also when I am full throttle the car gets to about 5500 rpm's and doesn't pull anymore, it that normal? Any help is appreciated. Thanks.
clutch sounds like a bad/ceased pilot bearing/throw out bearing....so when you push the clutch in it acts like it wants to stall correct?
TX Speed Demon said:
Did it start when you put in the pipes? Sounds like a boost leak to me too.
No it started later, but I did take them off and put them back on and it started shortly after that.
Yes that is correct. But some times if I leave it in gear and I am slowing down if I wait and push in the clutch at around 1500 rpm the idle will just drop to normal.
I just went and checked all the places I could to see if there was a loose part but no luck. Should I take the pipes off again and just put them back on making sure that they are tight. I hope it isn't anything serious cause I don't want to deal with the dealership again.
