i-ACTIV AWD Thread
2019 Mazda CX-9 Signature, Machine Grey Metallic
Thought I would start a thread specific to the i-ACTIV AWD system that the CX-9 will have. So far, reviews have been quite favorable and seems to exceed the Subaru Symmetrical AWD system in CVT-equipped Subaru vehicles, which is considered as the current benchmark.
[VIDEO=youtube;PUXCKaR9ZUo]2016 Mazda CX-5 vs Honda CR-V vs Subaru Forester AWD Snow Traction Mashup Review[/VIDEO]
[VIDEO=youtube;SJVtxV5oslk]Mazda i-ACTIV AWD (Japanese with English subtitles[/VIDEO]
Snow Testing Mazdas i-ACTIV All-Wheel Drive (Autoguide)
Snow Testing Mazda’s i-ACTIV All-Wheel Drive (Autoguide) :
When you think of all-wheel drive, do you think of Mazda?
Chances are the answer is no and Mazda is fully aware of that. To help change perceptions about the brand’s all-wheel drive prowess, Mazda invited us to Crested Butte, Colorado to put the brand’s i-ACTIV all-wheel drive systems to the test.
For those not familiar with the specifics of all-wheel drive (AWD) mechanics, there are basically two types of AWD systems on the market today. The first are full-time AWD like Audi and Subaru utilize, while the other is an on-demand set-up, used by the majority of the industry.
The reason on-demand is more popular is that full time all-wheel drive needs a longitudinal engine layout to work effectively, which most front-wheel drive based cars do not possess. Conventional wisdom is that a full-time AWD system is the superior set-up but with today’s advances in engineering, Mazda thinks i-ACTIV is just as good – or maybe even better. Can that really be?
Not Your Father’s Slip and Grip
‘Slip and grip’ is a colloquial term used by AWD elitists to describe rudimentary, ineffective AWD systems. I know this because I’m one. In the past, any all-wheel drive system that didn’t consistently send power to the front and rear wheels unless slippage was detected fell under this category and thus was obviously inferior.
But times have changed and so has technology. Heck, even Subaru, stalwarts of full-time AWD, now uses a modified on-demand system in CVT-equipped vehicles.
Mazda has a more traditional on-demand all-wheel drive system that the company is quick to point is anything but slip and grip. Introduced in the 2013 CX-5 crossover, the system is of course called i-ACTIV all-wheel drive because, well, Mazda needs to ACTIV all the things.
i-ACTIV AWD
In normal operation, i-ACTIV AWD does send approximately 98 percent of the vehicle’s power to the front wheels. But the vehicle’s computer and 27 sensors monitor factors like steering torque, steering angle, front and rear wiper motor speed, outside temperature, longitudinal g forces, electric steering motor current, gas pedal position, gear position, brake pressure, wheel speed, engine rpm and the vehicle’s incline angle at an amazing 200 times per second.
A central control module then predicts and determines how the wheels need to be driven and send upwards of 50 percent of the engine’s power to the rear wheels before the front wheels begin to slip. But, if the front wheels have absolutely no traction, the rear differential can accommodate 100% of the engine’s torque if needed.
And that rear differential features 82% less energy loss than Mazda’s old AWD system. i-ACTIV as a whole is 84 pounds lighter in the CX-5 compared the one installed in the CX-7 and the all-new CX-9’s i-ACTIV sheds 57 pounds compared to the outgoing model.
Rear Tires Are Actually Powered Most of the Time
But the system is more than just light weight and quick reactions. Mazda studied the relationship between what people recognize as wheel spin compared to how much actual wheel spin is occurring. There’s more wheel spin happening than we realize and to ensure the all-wheel drive performance feels natural, Mazda allows certain amounts of wheel spin to occur in slippery conditions.
And while on the topic of wheel spin, it’s a little known fact that tires are always slipping a bit, even on dry pavement. This is the reason power is sent to the rear wheels, even in dry conditions. It reduces the front tire slip and associated energy waste enough to overcome the small amount of power that’s being sent to the rear wheels.
Electro Diff, But No Torque Vectoring
A big change in the world of differentials is the movement away from hydraulic looking center couplings to electronically controlled ones like found in Mazda’s i-ACTIV. By using an electromagnetically activated clutch, the rear wheel torque matches exactly what the computer is dictating unlike a hydraulic clutch pack that cannot vary the amount of torque to the rear wheels as quickly or as often. It’s like the gracefulness of ballet replacing the hammer forward approach of crunk.
One thing i-ACTIV AWD does not do is torque vector in any form. The stability and traction control systems will brake individual wheels to send power to the wheels with grip, but the all-wheel drive system cannot send power to an individual wheel nor does it brake individual wheels for pseudo torque-vectoring.
Enough Shop Talk, How Does it Work?
Alright, now that I’ve gone over all the gooey details; how does it work in the real world? Mazda set up a few real-world driving situations in Crested Butte and brought along the CX-5’s main rivals – a Subaru Forester, Honda CR-V and Toyota RAV4. And yes, all the vehicles wore identical Bridgestone Blizzak winter tires.
First up I drove the CX-5. Along a snow covered, steeply angled mountain road the vehicle never felt like it was fighting for traction. Grip was always there. It felt sure footed under acceleration, braking and cornering.
The one nuance I found was that, as expected, the i-ACTIV AWD does not help with cornering. Apply power mid corner in the snow and the CX-5 will begin sliding nose first for a snow bank. But most owners of the CX-5 will not be trying to snow-drift the crossover and when not driven like a manic, it takes a lot of drama out of wintry driving.
So How Did the Competition Do?
Next up was the Toyota RAV4. It uses what Toyota calls dynamic torque control all-wheel drive. Mechanically, it’s a set-up similar to that of Mazda’s. On the snowy test roads, the RAV4 felt less certain under braking, as the rear end would dart around under moderate braking. It also produces more rear-end rotation during throttle-off over-steer, which is fun for someone like me, but may be a bit unnerving for a consumer.
The Toyota also fought harder for traction when climbing some of the steeper hills. On nice plus for the RAV4 is the fact it can be locked into all-wheel drive via button on the dashboard, but unless the vehicle is at a complete stop, it doesn’t make that much difference.
Next up was the Honda CR-V, which also now uses an electronic center coupler but feels cruder than all the other systems here. It allows the front tires to spin quite a bit before the clutch engages the rear tires. It had the hardest time finding traction on inclines and was the most apt to produces moderate amounts of throttle-off over-steer. Easily, the CR-V was the least predictable crossover on snow and ice.
But What About the Subaru?
Last up was the vehicle known for all-wheel drive superiority – the Subaru Forester. After a few minutes driving around on the slick mountain roads, I found there is not much performance difference between it and the CX-5 when it came to acceleration, cornering or braking capabilities. That’s saying something since Subaru is so well known for the brand’s all-wheel drive systems.
But then again, the all-wheel drive system Subaru offers with the brand’s CVT equipped models is closer to the that of a slip and grip system than the old constant ratio AWD setups. Even with this more front-wheel bias system, the Forester is still the most willing to slide the tail out under throttle and feels the easiest to modulate at my will. But it’s nothing like the tail-happy, I-wanna-be-like-Colin-McRae Subbies of old. And when climbing a steep, snow covered incline, the Forester struggled for grip more than the CX-5 did.
The Verdict: Snow Testing Mazda’s i-ACTIV All-Wheel Drive
Did Mazda’s i-ACTIV all-wheel drive blow away the competition? No, no it didn’t. And Mazda wasn’t expecting to. What Mazda wanted to prove is that i-ACTIV is just as good as anything the competition has to offer and may hold a few advantages here and there. In that quest, Mazda has succeeded.
Wow
The video shows the i-ACTIV AWD diagonal and offroad tests were not as expected.
[video=youtube;AhacSO7uMys]i-ACTIV AWD Test: 2017 Mazda CX-9 | Diagonal and Offroad test![/video]
For comparison, here are the CX-3 and CX-5 tests.
[video=youtube;n-uAtG9gCvM]Mazda Cx-3 2016 Awd diagonal test[/video]
[video=youtube;hbFaox-jZ5Y]Mazda Cx-5 GT 2016 - Awd diagonal test [/video]
So Mazda seems changed something in 2nd-gen CX-9's i-Activ AWD system which makes this diagonal and offroad tests failed?
Yup, seems like it, to the detriment of the CX-9. I hope that someone from Mazda's engineering team has seen the video and is able to make the necessary software adjustments to the i-ACTIV AWD system to address this.
I doubt Mazda will do that even though you and I think they should. I had been looking for a diagonal test like this and now kind of wished I hadn't seen it. Very disappointed in this given how well the system in the CX-3 and CX-5 is.
These are road cars on stilts. Vast majority of CUV drivers never need more clearance than they would get in regular sedan, or take it where a sedan couldn't go as well. I mean, if you are off-roading in a family CUV on terrain that emulates the test above, you'd probably have torn up the bottom of the car already, seeing as there is no skid plate.. drop a gear and enjoy the system where it excels most.
Appears the lack of torque vectoring is allowing the two non traction wheels to spin. I-ACTIV AWD appears to only control the torque/power between the front and rear drive but not using the 27 sensors ( assume includes ABS wheel sensors) to detect relative wheel spin between the wheels on the same axle. Wonder if applying the brakes, lightly/moderately, at the same time might cause the ABS to kick in and apply braking to the spinning wheel and thus allow the torque to then go to the non-spinning wheel on each axle
CX-5 in different video didn't show the incapability of doing it, and CX-5 doesn't have Torque Vectoring until new 2nd-gen 2017 CX-5. Besides, Torque Vectoring is not for this kind of situation during diagonal and offroad tests.
Or the weight/weight distribution caused during the test could cause the poor results.
Interesting that in tests like this, Subaru usually does very well.
"Apply power mid corner in the snow and the CX-5 will begin sliding nose first for a snow bank."
I've felt a bit of this, but it is easily handled with judicious throttle use.
The one thing I'd like to see added is an AWD lock for 4 wheel engine braking on long downhill slippery grades. Now you only get front wheel engine braking.
I like the way my new CX9 handles on snow, both deep snow and hard polished snow. Blizzak DM-V2 tires on the CX 9, and I'm ready to go!
i-ACTIV AWD Thread - "4WD Heavy Load"
It seems that more issues are found on i-Activ AWD system in new CX-9. I was wondering who else had experienced this?
Uh, we had a major issue yesterday with our 16' CX-9 GT. We're staying up at a resort hotel at the top of a mountain in Maine. During that snowstorm, we encountered a warning 3/4 way up the mountain stating "4WD Heavy Load" - and then the 4WD stopped working, reverting the car to FWD only. We literally had to turn off the car to reset it and turn it back on several times to make it up.
There was a definite "hot" smell coming from under the car - I have to imagine we really stressed the clutch? that controls power to the rear wheels. Very concerned about the longevity of the AWD transmission if something like this causes the system to fail.
wow, that's not good, either the clutch like you said or the front transfer case overheated giving off the burning smell
video also shows the same warning you got below 0:47 seconds mark,
doesn't look like Mazda AWD system can carry the extra weight on the CX-9
Did just that earlier today - dealer appt on Friday morning, and they offered a loaner. Happened again tonight when trying to back into a snow-covered parking spot. Not good.
wait, you said it happened again? on your car or on the loaner ? if the loaner, than it's not an isolated incident, and an inherent design flaw
Whoever this is with the hot smell, I'd change fluids out immediately.
very bad the cx9 don't pass this "test" but in real life scenarios the AWD in my cx9 turbo works very well!. We have a really high hill near my work and I see most FWD high end cars and SUV to slip all the time. And when raining and the street is wet, uf! people really had bad moments there! I see big SUV failing to go up hill and the cx9 pass with flying colors!
Latest posts
