Hwy 9 Fun Run!
Roywhitep5 said:
damn mods took off my naked cartman avatar
Translation: No naked Cartoons as an avatar. Even though it was on National Television, we still deem it unacceptable and dirty. (jerkit)
Beam pattern is awesome. You know how road signs are just bright as hell with the HID's with the normal reflector? The beam is so precise on these that when the car bounces you can actually see the cut off line on signs
Ahhh **** **** ****! So I was driving along the freeway tongiht and I start to hear this rubbing sound coming from the front passenger side wheel. The noise is proportional to my speed so it is something rotational. I'm almost home anyway so I drive slowly and limp it home. I already know what the problem is because it happened before. My wheel was coming loose. I say no problem when I get home I will just tighten the bolts up. So I get home and tighten them up out on the street just so I can drive it up into the garage. I get in and jack it up three bolts come loose and the other two, well those just decided to loosen a little and then stop turning. The bolts on the hub or the nuts are ******* stripped! I can actually hear the bolts making a grinding sound as I turn it past the points where they do turn easily. WTF do I do? Is this a problem a place like les schwab can deal with or is this a dealer thing? Would something like this be covered under warranty or what and if not how much do you think something like this would cost me to repair. This sux so ******* much I hate it. I can't even do anything about it right now. All I can do is sit and stew because the dealership is closed at this time. I'm pissed!
Did you do your own tire rotations or take it to the dealer?
If the dealer did it then you can take it there and say they stripped the bolts.
If not they probably won't warranty it and say whoever rotated it stripped the bolts.
Looked at the service manual, its not that big a job to remove the hub. The part will
probably be expensive but the look of it the labor shouldn't be much.
