I would buy a 4ga wiring kit from
www.knukonceptz.com. You will also need a LOC from
www.davidnavone.com if you want to use the stock head unit.
The amp you have is 80x4 or 250x2. There are plenty of how-tos on this forum and the internet to guide you through installing an amplifier.
80 watts is a bit overkill for the stock speakers. They won't last very long with that kind of power. I would recommend upgrading the front speakers with a set of components ($115 and up) and getting a small subwoofer for the hatch (a JL Audio 10w3v2 dual 2ohm will work great but any 4ohm or dual 2ohm sub rated for 200-400 watts will work). There are also some nice 8" subs if you are looking to save space.
I do not recommend doing anything with the rear speakers. You don't need them to get a "loud" system and they only hurt the SQ of the system by pulling the sound stage to the rear of the car.
