How to route coolant lines for a Turbo and MSP oil cooler?
I managed to get an original MSP oil cooler and bolt for 75 dollars to go with my turbo system. I am confused as to the routing of the coolant lines. So far, I am planning on using a banjo bolt on the port right next to the oil filter and attach it to the oil cooler. from there I will connect a line to the cooler outlet that goes to the turbo. I am wondering where I should have the coolant outlet from the turbo plumbed. I am also not sure if I have this backwards and the turbo should feed the cooler
