How to remove the Fog lights?
If you talking about a P5 ,you dont need to remove the bumper , there are splash guards inder the bumper you have to remove them , then you can access the 14mm nuts on the bolt of the light bracket . undo the nut the lights come out the front ,undo the wire clip to the lights . Two scews hold the housing together ,undo them .the bulbs are H-3 . put back together in reverse
