((I DID A HUNT))
And I came up EMPTY. The only thing I really need is where do I hook up the o2 wirer?
Hook up your wire's the same as you did the BG and run the green wire thru the FW{I ran mine around the front and back to the ECU} and @ the first plug to the left of the battery and the fifth wire on the left rear side of the plug is White. Tap that wire and your good to go.
Note: This Prosport Digital AFR/Volt gauge does not just around like most I have seen.
