How to get an accurate oil level reading!
auto_carr
2007 MX-5 Miata Grand Touring Marble White
After an oil change the oil level on the dipstick still looked like it was on the add mark. Apparently the material they made the dipstick out of does not hold the oil so there is only a thin sheen on the stick that is almost impossible to see. Then I had an idea that was so counter intuitive to all my previous dipstick checking habits that I didn't think it would work. I pulled the dipstick and immediately turned it horizontal with the tip slightly down. With the cut out for the oil indicator marks facing me and slightly tilted back at the top, the oil level magically appeared along the bottom edge of the cut out right up to the full marker.
To test that it is accurate, wipe off the dipstick and only push it in until the o-ring just touches and then follow the above procedure. You should see the oil pool on the edge at about the add marker.
