Tape them up with electrical tape and leave them.323CiP5 said:What do you do with the BLUE/ORANGE wire from the DRL module on the connector side,
RED wire from Fog Light Module on the harness side, and the RED/WHITE wire from the Fog Light Switch on the harness side?
Maxx Mazda said:Sweet man. I didn't use a switch for the DRL's either. I jsut grounded them out too. But I meant to ask, does your e-brake light work as it's supposed to? Mine turns off 3 seconds after starting the car even if the brake is on... Yours?
Ya, I talked to Josh (Net_Guy) yesterday, and he showed me his car. The E-brake light on his car after the mod works as it's supposed to. I'm not sure what I did wrong, but I wouldn't mind it being fixed.fvellani said:I just did this mod last Thursday, so thanks to Bumble G for the how-to. Its great to be able to have control of all the lights.
By the way, My e-brake light doesnt work either.
fvellani said:HiKsFiles, the mod works perfectly fine, looks good, the only problem is that the parking brake light doesn't come on when the brake is on. I doubt that will be a problem, as it's pretty easy to tell when the brake is on, and I figure it's routine for most people, if you put the brake on when you leave the car, you'll automatically just reach to put it back down when you need to drive...not a problem at all, for me at least.
My light does not work as it should for the e-brake, but I can vouch that it does still work for the low fluid level. I'm still trying to figure this one out, but I'm not losing sleep over it!joecanadian said:I wouldn't mind the fact that there was no light when the e-brake was on. But, I DO want to know if I ever run low on brake fluid (that light is used for a low fluid warning as well). That's the reason some people are a little hesitant to do this mod. BTW, I just picked up a factory service manual so maybe I'll look into a way around this problem if I get some time. I'm not driving my car now (it's in storage until spring) so I will probably get a chance to try some things out.
Thanx Joe!BTW, I just picked up a factory service manual so maybe I'll look into a way around this problem if I get some time. I'm not driving my car now (it's in storage until spring) so I will probably get a chance to try some things out.
