misbehave said:I have a very very dumb question.
Do you need to tug up the engine to take out the mounts?
And if not, how is the engine supported after you took the mounts out? Or the wheel/axle will support it when you are not moving the car.
ok...thanks man. I don't know may be I did something wrong. I cleaned the rubber inside and put the windo weld inside with a big coat (may be that's why it doesn't dry so fast) and it is still like liquid? How did you make your with windo weld? (could you give me detail instructions)iluvmacs said:I let it dry the whole weekend. It must not be sticky to the touch. Still, after the outside dries, if you put it back in the car the inside which hasn't dried will be pushed out and you'll get nothing out of all your work.
Leave it for 2-5 days outside the car.
