TOC
Removing the Front Calipers
Rebuilding the Front Calipers
Removing the Front Brake Pads
Removing the Front Rotors
Removing the Rear Caliper
Rebuilding the back Caliper
Removing the back Brake Pads
Removing the back Rotors
Bleeding the brakes.
Obviously the first steps are to jack up the car and put it on stands. Make sure it is secure before doing any work.
This write up is meant to be instructional but not the end all. Different models have different bolts and sizes. Any work you do is done at your own risk. I can not take responsibility for mistakes or issues.
I decided to rebuild my brakes after feeling some sponginess and pulsing in the brake pedal. Also when I took the apart I found the Dust shields on all four calipers to be torn and in a generally piss poor shape.
JOB DONE!
JOB DONE!
