Spooled said:No, my setup tells the ECU that the second O2 is there and working fine. ...... Plus it's not in the exhaust flow, so there is less restriction.
Thats just it. If I'm not mistaken, you're running without the rear O2 installed and the ECU is thinking its there and is OK. I'm runnin it for emissions and economy purposes. The nonfouler route still utilizes the rear O2 to help keep emissions under control, without fudging the voltage sent to the ECU. If I ran the MIL eleiminator, I wouldn't have known what was going on. My O2 took a s*** and the ECU caught the problem...thus the CEL coming on. If you're rear O2 ever took a s*** on you, you would never know because of the setup that your running (but I could be wrong)....but since it's not even installed, it doesn't matter!
