KzA said:If i plan on getting a turbo, would it be a problem if I installed this gauge before the turbo? You just plug the sensor into the new bung, right? I wouldnt have to run it all over again right?
Terry said it would be a problem with heat shortening the life of the O2 sensor, plus, when they are overheated, they will give innacurate readings.
I already tested this when I was N/A. Plugged the New O2 sensor in the manifold and it overheats @ high loads, 4th or 5th gear.
